Doesn't Unlimited Anytime minutes mean no extra charge for incoming-outgoing calls (within Canada)?
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
I switched my plan to the CAN Data 1G Ultd min QC $45 specifically so that I would have access to Unlimited Anytime minutes. Why am I still being charged extra for local antenna time?!
Photo of EmK
EmK
  • 80 Points 75 badge 2x thumb
  • frustrated
Photo of Ivan
Ivan, Mobile Master
You are correct. There should be no charge for calls to/from any Canadian number, as long as you are in Canada.
If you are being charged for airtime, then I advise you to get in touch with customer service to resolve the issue. Call 611 from your Koodo phone, or:
Photo of Camilo_A
Camilo_A
  • 31,072 Points 20k badge 2x thumb
Hi there...
From what I see here, probably what you see on your bill are minutes used prior you changed your plan...
I recommend you to check your bill on the Self Service account, and check the dates for those calls, pretty sure you will get the answer...
