does unlimited incoming charge long distance
I have Unlimited Incoming. Does unlimited incoming charge long distance. If my local area is Toronto, and I happen to be in Vancouver, and someone calls me, (call originates in Toronto) will I be charged Long Distance because the call is now bounced to Vancouver.
Photo of Steve Potts
Steve Potts
  • 232 Points 100 badge 2x thumb
Photo of Malcom Holmes
Malcom Holmes
  • 144 Points 100 badge 2x thumb
If your plan is a CanadA Wide yes you will be cover for LD
Steve Potts
Will this go against my Cda Wide minutes even though it is incoming? I ask this because unlimited evening/weekends states that it is only for local minutes
Malcom Holmes
If you plan inclueds unlimited incoming calls and you have a Canada Wide plan You wont pay LD charges and the minutes the incoming call last wont be taken out of the minutes that your plan inclueds, the minutes of your plan will only taken off whenever you call out only.
Steve Potts
perfect - thanks
Photo of Robert
Robert, Mobile Master
  • 103,444 Points 100k badge 2x thumb
What plan do you have and where have you seen such a statement?
Also, keep in mind that your local time will be based on the city you're in. If you have unlimited evenings and weekends and someone call you at 6PM from Toronto and it's 3PM in vancouver, you will not be using your unlimited minutes
Photo of Jonathan
Jonathan
  • 816 Points 500 badge 2x thumb
Unlimited Incoming Calls include airtime only, subject to long distance charges when outside the local calling area if your plan is a local one.
