Does the samsung galaxy S2X from koodo work with wind mobile?
Not too impressed with Koodo's plan, but I like my the G2sx. I was thinking of getting it unlocked and going over to wind. Does anybody know if it's possible?
Photo of litdan22
litdan22
  • 128 Points 100 badge 2x thumb
Photo of Cire ©
Cire ©
  • 908 Points 500 badge 2x thumb
If you unlock it take it anywhere you want.
Photo of Marcus Fenix
Marcus Fenix
  • 15,752 Points 10k badge 2x thumb
You could call and ask Wind....
Photo of Sophia
Sophia, Mobile Master
  • 143,044 Points 100k badge 2x thumb
I'm not sure if the S2X has the band Wind requires.. something like 1700? If it does, as mentioned above you can take your phone wherever you like - as long as it's paid for :)
Photo of Humberto Giambrone
Humberto Giambrone
  • 4,900 Points 4k badge 2x thumb
S2X is quad band and supports 1700mhz, it should work in theory
Photo of litdan22
litdan22
Yeah some people said they used it on wind, thanks for doing the research.
Photo of MatB
MatB
  • 32,478 Points 20k badge 2x thumb
Easy way to find out is trying Wind SIM
Photo of Michelle Andrea
Michelle Andrea
  • 60 Points
i have mine from koodo and it works perfectly with wind
Photo of Myke
Myke
This is a 3 month old thread with no activity. There is no need to post in this thread.
Photo of litdan22
litdan22
Thanks Cire, I would imagine it would work anyway but I'll call anyways to be safe like Fenix said. If anyone has switched with the G2SX please tell me about it and your experiences with wind
Marcus Fenix
If you don't mind being restricted, it's alright....
Marcus Fenix
If you go outside of your local calling area, you get a roaming charge of $0.25/minute.
Photo of happy....
happy....
  • 798 Points 500 badge 2x thumb
Yes. It works on Wind mobile if its unlocked. I used it on Wind mobile.
Photo of litdan22
litdan22
Thats a pretty high rate, but I don't think it will be to hard to avoid roaming fees. And thanks happy, good to know the phone works with wind. Some guy at a mobile shop told me some bs about how its telus and it probably wouldnt work.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,676 Points 100k badge 2x thumb
It's not BS. Telus runs on the 850/1900 bands. The WIND Mobile network uses a frequency called AWS, with bands 1700/2100. Most phones sold by either provider are compatible with one or the other, but not both.
Photo of Chris Petersens
Chris Petersens
Hurry up before wind goes broke.....you also might want to do some extra checking. Wind's coverage is pretty bad and now that they are running out of money improvements won't happen. Some people are ok not being able to use their phones because the discount they are getting from wind. It all depends on how patient you are. Here is just one of the many reviews:
http://www.windmobilesucks.com/
Photo of Chris Farley
Chris Farley
  • 242 Points 100 badge 2x thumb
provide Wind when your IMEI # they will be able to determine if it's compatible with their network. If it is your phone needs to be unlocked
Photo of happy....
happy....
