does siri work only with data? or can it work with wifi?
Photo of David Hyatali
David Hyatali
  • 580 Points 500 badge 2x thumb
Photo of Alcide Robidoux
Alcide Robidoux
  • 1,994 Points 1k badge 2x thumb
Siri will work with both your network data connection and your WiFi connection.
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
As Alcide said yes it should work on both. However a lot of problems were reported when siri is used over wifi which is not the case when it is over a 3 G connection
So when are you buying the iPhone?
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
8 questions on buying it !!!so far!!!, still need to wait for some others !!
Dudes doing his research. Lol
Photo of MatB
MatB
Thx MM.
