Does Koodo show LTE,HSPI, or 4G on top of samsung galaxy s3(unlocked)?
Does Koodo show LTE or 4G on top of galaxy s3 (unlocked)screen, because mine doesn't. just switched to koodo from Telus and telus had LTE on top of screen
Photo of sartech131
sartech131
Photo of Ahmad
Ahmad
Yes it should
Photo of Jonathan I
Jonathan I, Mobile Master
You need the APN settings in the phone to get data access, after which you'll see the symbols.
https://c.getsatisfaction.com/koodo/t...
Photo of sartech131
sartech131
Phone doesn't show any type of data signal
Photo of sartech131
sartech131
Thanks, did all settings, still no data info
Goto settings...wireless and networks..mobile networks
Ensure data is enabled
Photo of sartech131
sartech131
Wifi off data on (no cap)
Photo of Jonathan I
Try restarting the phone and MAKE SURE you put in the APN settings precisely. One wrong letter, number, or symbol and it won't work.
