Does koodo have better prepaid plans than telus?
I have a telus prepaid (which i lost the phone now but im trying to buy the Samsung SIII or samsung ace 2 ) and I think I should go with koodo but i do not know if koodo has better prepaid plans then telus?
Photo of Joelle Wendy Faught
Photo of Sophia
Sophia, Mobile Master
It depends on what you are looking for, Joelie. There are quite a number of differences between Telus and Koodo in their prepaid plans, rather than list them for you (which I did today - in another thread already anyway) :)
Can you tell us what you are looking for in prepaid? Then I'll tell you honestly which one might be better for you :D
Photo of Taras Bohomol
Taras Bohomol
  • 60 Points
koodo is better for sure anyway)
i use it
Photo of Ivan
Ivan, Mobile Master
In my opinion, Koodo has the best prepaid plans in Canada due to the non-expiring talk and data boosters (as long as you maintain your base plan). My advice is to compare the plans yourself and see if you agree.
