Does the Xiaomi Note 4 MTK work on Koodo LTE
  • Updated 1 year ago
Here is the bands the phone supports.. I just don't know if Koodo supports them. A definite answer would be great.. thanks
LTE band 1(2100), 3(1800), 5(850), 7(2600), 8(900), 38(2600), 39(1900), 40(2300), 41(2500)
Photo of Bill Than
Bill Than
Posted 1 year ago
Photo of Suresh Aryal
Suresh Aryal
  • 1,056 Points 1k badge 2x thumb
Koodo is on AWS (1700/2100) band on LTE. Since I see 2100 band on the specs, it should work but reception may not be perfect.
Photo of BobTheElectrician
BobTheElectrician
  • 67,538 Points 50k badge 2x thumb
LTE will not work correctly. You need band 4 (1700/2100).
When shopping around, best to check out:
willmyphonework.net
Photo of rikkster
rikkster, Mobile Master
  • 68,350 Points 50k badge 2x thumb
Not LTE related, but I don't see Band 2 listed, (1900 MHz - FDD). Band 39 (1900 MHz - TDD) uses a different set of frequencies and a duplex mode that is not compatible with Koodo's 3G network. Koodo uses 850 MHz and 1900 MHz (or Bands 5 & 2) for their HSPA (3G) network.
Photo of Goran
Goran, Mobile Master
  • 97,688 Points 50k badge 2x thumb
Aws requires 1700 and 2100 down the downlink and unlink. I'd aim for the note 4x since it has 2600mhz lte whichever Koodo (Telus) uses forward lte-a.
Photo of Goran
Holy typos batman!
Aws requires 1700 and 2100 for the downlink and unlink. I'd aim for the note 4x since it has 2600mhz lte which Koodo (Telus) uses for lte-a.
Photo of Allan
Allan, Mobile Master
  • 62,836 Points 50k badge 2x thumb
For LTE AWS (1700/2100) you need both bands to work so LTE will not work with Koodo. 3G however will work as the phone has 850, 1900.
