does the prepaid plan work if i travel within canada
  • Updated 2 years ago
I live in montreal and traveling to toronto. I have the 35 dollar prepaid plan. will my phone work?
Photo of Naomi
Naomi
Posted 2 years ago
Photo of David
David, Mobile Master
  • 93,788 Points 50k badge 2x thumb
Yes. Your incoming calls are included in that plan, no matter where you go in Canada, and your outgoing calls are covered up to the number of minutes you have in your booster.
Photo of Goran
Goran, Mobile Master
  • 97,682 Points 50k badge 2x thumb
Yes. It will work anywhere in Canada. Now, with the 35 you get unlimited incoming calls nationwide. So you won't have to dip into any minutes to receive calls. It gives unlimited outgoing after 5pm, which also applies nationwide. There's no local roaming limitations. It's unchanged from your usage in Montreal.
