Does the international roaming add-on 40$ plan work in Tahiti?
  • Updated 1 year ago
I would like confirmation that the koodo international roaming works in Tahiti. The international partner plan doesn't specify Tahiti.
Photo of hookoo3
hookoo3
Posted 1 year ago
Photo of Zeta Abramovic
Zeta Abramovic
  • 2,244 Points 2k badge 2x thumb
I'm quite sure it still does. It did for us last year. You can always get it and if there is no coverage get your money back.
Photo of David
David, Mobile Master
  • 93,614 Points 50k badge 2x thumb
A quick check of Telus' website indicates they have no roaming partner in Tahiti. I expect Koodo is the same, and a roaming option is not available.
Photo of Goran
Goran, Mobile Master
  • 97,448 Points 50k badge 2x thumb
The roaming add-on states it's for any country except the US and it's territories. However, the list of roaming partners has nothing for Tahiti atm. You can always buy a local Sim card and then use messaging services or fongo or Textnow to get a Canadian number to use. It's expensive but you'll get a lot more usage out of 40 dollars still than the roaming add-on Koodo has for data and talk.
