Does koodo need my imei number from phone for LTE to work correctly
  • Updated 2 years ago
Photo of Garth
Garth
  • 172 Points 100 badge 2x thumb
  • frustrated
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 106,876 Points 100k badge 2x thumb
Hello Garth.
No they do not. LTE should work fine without that information. Isn't it the case?
Photo of Garth
Garth
Not sure did update to 6.0.1 on my note 5 and lte does not work anymore ,tried everything and every suggestion from samsung and koodo ,and general public ,only left to do is root phone to fix problem
Photo of rikkster
rikkster, Mobile Master
  • 68,314 Points 50k badge 2x thumb
There are two methods to try and recover a 'failed' update. One is to head over to SamMobile and download the latest firmware image specific to the model number of your Note 5 and flash it using Odin, no root required. The other is to use Samsung's Smart Switch 'Emergency software recovery and initialization' tool. Again, no root required.
Note 5 firmware - SM-N920W8 - (firmware files for TELUS & Koodo are identical)
http://www.sammobile.com/firmwares/da...
Smart Switch
http://www.samsung.com/ca/support/sma...
Photo of Levis
Levis, Employee
  • 2,174 Points 2k badge 2x thumb
Hey Garth, from which company is your Note5 from? Did you update the phone via an "Over The Air" update that was pushed, or did you update some other way?
