Does koodo sell phone cases for Essiential PH1?
  • Updated 2 months ago
  • (Edited)
Photo of suzi yac
suzi yac
  • 352 Points 250 badge 2x thumb
Posted 2 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 196,158 Points 100k badge 2x thumb
I don't think they do, they're very limited and pretty much impossible to find in stores, the best place to find them is Amazon or Ebay.
Photo of Dennis
Dennis, Mobile Master
  • 181,006 Points 100k badge 2x thumb
I've see a few of those cell phone case kiosks in malls that carry them.  Depending on your mall, you might try your luck there too
Photo of suzi yac
suzi yac
Thanks for the reply Dennis.I will try to see if they have any at the mall.
Photo of Goran
Goran, Mobile Master
  • 86,094 Points 50k badge 2x thumb
It's always overpriced anyways unless you can get it for half off from carrier stores anyways. Online is your best bet.
Photo of Dennis
If you get the dirt cheap ones from china on ebay, expect it to take over a month or 2 to arrive
Photo of suzi yac
suzi yac
Thank you. I think online will be the best way to go.
Photo of Pix Bylorne
Pix Bylorne
  • 134 Points 100 badge 2x thumb
Suzy, amazon.ca has lots of cases for the Essential.     How do you like the phone? I like the look and the feel of it but the reviews are very mixed.
Photo of suzi yac
suzi yac
I haven't got it yet, I ordered it online and I am waiting for it to arrive but thought I should check for a case to get one . I read many reviews and your right they are mixed so I guess I have to wait and see and hopefully it was a good buy
Photo of Erwin
Erwin
  • 23,486 Points 20k badge 2x thumb
Hi Suzi,
Yes they do! come visit your closest Koodo corporate store. They have glass screen protectors too. To make sure they have it in-stock. I recommend calling in to that particular store and ask :)
  • 193,800 Points 100k badge 2x thumb
Good to know, they didn't have any when I was looking when I got my Essential.
