does it reset my billing cycle if I switch plans?
  • Updated 6 months ago
I want to switch to the 115$ plan for 10gb of data.. I'm on a 1gb +2gb data plan for 65$ +a 20$ 1gd add on. I have about 10 days left in my billing cycle. What happens to my bill and my data add on?
Photo of Destiny Fox
Destiny Fox
  • 124 Points 100 badge 2x thumb
Posted 6 months ago
Photo of Dennis
Dennis, Mobile Master
  • 196,588 Points 100k badge 2x thumb
No it does not.  Your billing cycle will always be the same.
It is recommended that you switch at the end of your billing cycle.
If you did switch part way in, your old plan and new plan will be prorated (21 days on the old plan and 10 days for the new plan).
This means your old and new talk and data should be pro-rated as well (but Koodo doesnt currently prorate data).
As for the $20 data add-on, I am unsure.  I believe it will be charged in full so you get to use the full data bucket in that add-on
Destiny Fox
Thanks! :)
