Does a Koodo Phone work in UK? I have an iPhone 6. Should I unlock it before I leave in case I need a UK sim?
  • Updated 1 week ago
Photo of helen dundass
helen dundass
  • 134 Points 100 badge 2x thumb
Posted 1 week ago
Photo of Dinh
Dinh, Mobile Master
  • 28,654 Points 20k badge 2x thumb
hi helen,
If your iPhone6 was unlocked, then it should work. If it wasn't you can try to follow the instructions in this https://www.koodomobile.com/help/unlocking-your-phone if you are a current customer.
If you are not a current customer, you could send message to their facebook or call Koodo to ask for the unlock.
helen dundass
I am a Koodo customer. I did not know I had to unlock my phone to use it abroad. I thought unlocking was only necessary if I was exchanging the SIM. So if I unlock it, it will work with my number ?
Photo of Karl
Karl, Employee
  • 422 Points 250 badge 2x thumb
@srlawren
Everything Everywhere, Hutchison,  Telefonica and Vodafone :)
You can find the list here: https://www.koodomobile.com/help/sites/default/files/easy_roam_pdf_0.pdf
Photo of Dennis
Dennis, Mobile Master
  • 182,206 Points 100k badge 2x thumb
omg.... so that's what EE stands for
Photo of TJ Smith
TJ Smith
  • 3,118 Points 3k badge 2x thumb
you learn new stuffs everyday mate
Photo of srlawren
srlawren
  • 1,172 Points 1k badge 2x thumb
Thanks Karl!
So, for anyone looking on willmyphonework.net and not able to find Hutchinson or Telefonica, I checked on Wikipedia and they operate 3 and O2, respectively.  So use those in the dropdown under UK.
@helen your iPhone 6 A1549 should work great in the UK.  I merged the willmyphonework.net compatbility info into the UK portion of the PDF taht @Karl linked, for your reference:
EDIT: click on the image to see the full-sized version
helen dundass
Excellent, I screen captured this ...THks
Photo of TJ Smith
TJ Smith
Hi Helen,
if you had issues in the past with not having reception while abroad I would go for the safest route and get a UK SIM. It would be cheaper (between 10 to 25£) and you get talk/text/data bundles.
Try those 2 companies (personal experience): Lycamobile UK or Three Mobile UK; both have 30 days Pay-as-You-Go for under 25£.
Enjoy your time on the old continent Helen.
Cheers
