Do the unlimited calls include incoming calls and outgoing long distance calls?
  • Updated 1 year ago
Photo of Paul Reid
Paul Reid
Posted 1 year ago
Photo of Robert
Robert, Mobile Master
  • 107,634 Points 100k badge 2x thumb
Hello Paul,
If you're on a Canada-wide plan, they do!
Photo of Jru Gordon
Jru Gordon
  • 9,144 Points 5k badge 2x thumb
Long distance w/in Canada only, not to the US
Hope this helps!
Photo of titaniumtux
titaniumtux
  • 12,952 Points 10k badge 2x thumb
Unlimited incoming, regardless of origin.
Outgoing unlimited Canada-wide, US is extra, and overseas is usually charged per minute with the exception of Koodo offering calling minutes add-ons for select overseas destinations.
On wifi or data, call the US free via Google Hangouts Dialer. If configured correctly, it'll display your Koodo number on your outbound call display.
Photo of Aslam
Aslam
Thanks for the inquiry, for my Package it is both incoming and outgoing calls covered and are unlimited .
titaniumtux
If you're on an unlimited nation-wide calling plan, then yes. If not, then no.
