Do long distance minutea shore up local minutes
  • Updated 1 year ago
The answer is probably No but I'll ask anyways.
There are plans that have 500 local minutes and 1000 international minutes. If I were to run out of local minutes would the international minutes be used in place?
Photo of JohnC
  • 1,708 Points 1k badge 2x thumb
Posted 1 year ago
Photo of Robert
Robert, Mobile Master
  • 101,414 Points 100k badge 2x thumb
Hello JohnC.
My answer would be the same as yours. I think the purpose of putting 2 categories is to distinguish one from the other. If not it would've been easier to put 1500 local & international minutes in one sentence.
Photo of Mayumi
Mayumi, Mobile Master
  • 111,356 Points 100k badge 2x thumb
Nitty Gritty from the site:
1000 bonus international long distance minutes apply to calls made to India, Germany, China, Hong Kong, Bangladesh, United Kingdom, Italy, Mexico, Australia & Taiwan.The minutes you use while travelling outside Canada are charged separately. The airtime required to connect your calls is drawn from your included plan minutes
It means you can make 1000 minutes call to those countries without international long distance charges.
It still use your included anytime minutes if you made calls during day time(outside of your unlimited minutes window)
