Do I need to turn on data roaming in the US?
  • Updated 1 year ago
I bought text and voice boosters for the US, do I need to turn on data roaming? I don't have it turned on right now and it tells me that no network is available.
Photo of ipadfsj
ipadfsj
  • 724 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 97,738 Points 50k badge 2x thumb
I assume that you are prepaid? For the US you do not need to put in the free roaming add-ons in self-serve. You'll need to turn on data roaming on your phone to use data in the states. So you cannot connect to any network? Do you have your phone set to manually connect to Koodo or to just connect to any network?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,726 Points 100k badge 2x thumb
Just to clarify: if you do not wish to use data in the US, there is no need to enable data roaming. Voice and text should work just fine with it switched off.
Photo of ipadfsj
ipadfsj
Thanks got it figured out after I posted , the network was set to automatic once I turned that off then the networks came up and I picked AT&T and it's working
Photo of Allan
Allan, Mobile Master
  • 62,856 Points 50k badge 2x thumb
Just remember to switch it back once you get to Canada so you can connect to Koodo!
