Do I get charged long distance charges if I answer a long distance call on my cell phone.
  • Updated 2 years ago
Photo of Shirley Ann Wood
Shirley Ann Wood
Posted 2 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 62,198 Points 50k badge 2x thumb
If you have a Canada-wide plan, you can answer any incoming call using your standard plan minutes or free period without surcharge as long as you are physically located in Canada.
Photo of Lorraine Shepherd
Lorraine Shepherd
  • 94 Points 75 badge 2x thumb
So someone who calls from B.C. to Ontario has to call after 5 pm my time so I don't get charged wow! I love that. I was REALLY worried about that, then I would be charged 50 cents a minute not in my time, is that correct?? Same as me phoning there not in my free time?   Thank you.
Photo of David
David, Mobile Master
  • 89,280 Points 50k badge 2x thumb
If you are receiving the call you are not charged long distance fees, but the caller may depending on the plan they have. NOTE: if you have a plan with local minutes only, AND are out of your home territory, you would pay the long distances costs between your home zone, and your current location. Since most Koodo plans are Canada-wide, no long distance applies to Koodo users.
