Disconnect and forward home phone to cellphone
  • 3
  • Updated 2 years ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: archiving 611
I am moving out of my place and going to another province for 2 months. I would like to disconnected my home phone but keep the number on my cellphone.  What do I need to do, how much it will cost? Do I get charged for long distance incoming and outgoing call on my home number?
Photo of Nat
Nat
Posted 2 years ago
  • 3
Photo of Danny
Danny
  • 3,454 Points 3k badge 2x thumb
if I understand, you want to port your landline to your koodo account?  This doesn't cost anything.  If you have a canada-wide plan (and I think they are all canada-wide now), you're just paying for the minutes you use.  no roaming in Canada.
Photo of Nat
Nat
I have used call forwarding before but this time I want to cancel my landline services but keep my number. Any idea?
Photo of Danny
Danny
ya.  Just call *611 and tell them you want to port the number into koodo
Photo of Danny
Danny
also, you could call Telus' porting centre (Koodo's parent company) directly:
 1-844-232-7678
Photo of Nat
Nat
Thank you so much. That was helpful
Photo of Danny
Danny
fyi...  the number you want to port has to be active.  don't cancel your service first.
Photo of Nat
Nat
ok
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Or you can do this through self serve.
Log into self serve > Change phone number(scroll down  the page) > choose Option 2 - I want to move a number : it will tell you if the number is eligible to move or not > submit and follow instructions.
It  takes about 2 business days to complete porting from landline to cell.
By doing this however you will loose your cell phone number if that's important to you.
Other alternatives are to port your home phone to a voip provider like voip.ms and then set it to forward to your cell number. There's a minimum deposit of 25$,and they take 10$ of that to port your number in. Porting to a voip provider can take 7 days.
Cost to keep your number there can be as low as 85 cents per month
Calls are .009 cents per minute for incomming calls or you can pay a flat rate per month
Photo of Danny
Danny
I love voip.ms  I've been with them 6 years.
Photo of BobTheElectrician
BobTheElectrician
  • 61,736 Points 50k badge 2x thumb
My gawwwd... a topic where everyone agrees. Makes this whole forum worthwhile.
Photo of Philippe
Philippe
  • 220 Points 100 badge 2x thumb
I’m moving from Montreal to Toronto. I have a Koodo phone number with a Montreal area code. If I understand this discussion correctly, I can get a phone number for Toronto, which will be local and more useful as everybody in Toronto won’t have to call me using the Montreal area code (which is long distance for many callers in Toronto). I would get this local phone number from a service such as voip.ms or CallCentris. They will forward any incoming call to this local (Toronto) phone number to the actual phone number I have with Koodo. No need to do any forwarding with Koodo. And I would pay a fixed (one time) deposit and a small fee per minute on any call made with the local phone number I get from them. Meanwhile, the original phone number I have with Koodo will keep working normally. Is this correct?
You got it Phillipe
You deposit a minimum of 25$ USD to voip.ms
They charge a small fee to setup your DID.
You then setup the DID to forward all calls to your montreal cell number.
You can also set it up so you can call your Toronto peeps using your Toronto number on their Caller ID. Voip.ms has a wiki for everything they offer. Makes everything very easy.
You can even turn on SMS and have that forwarded to your Montreal number or email or both. Or download the voip.ms text app for android.
https://play.google.com/store/apps/de...
Make sure to read the app description for setup directions.
Photo of Philippe
Philippe
Super! Thanks Chad, really appreciate it.
