Different sims for prepaid and regular plans?
I've been trying to buy a koodo sim card and the local walmart only sells regular plan sims and they say they don't carry sims for prepaid. They are the only koodo dealer in town
Looking to order online, but from what I can tell on the website, there isn't any indication which type are the sim cards. The sims labeled as prepaid only have regular plans as option.
How can you tell them apart and can you order sims for prepaid online?
Photo of Steve
Steve
Posted 3 years ago
Photo of Ahmad
Ahmad
Hey Steve. If you look under accessories, you can see all the options for sim cards including prepaid ones. Just choose the one that says "Koodo Prepaid *Size* SIM Card" and by choosing the size you want (regular, micro or nano). It says $20 activation bonus underneath. That's the one you want for prepaid. (https://shop.koodomobile.com/phones/a...). Just add it to your cart and then press "check out now".
