Difference between Int'l Dialing & LD Saver and International Long Distance Saver
I currently have Int'l Dialing & LD Saver at $2 a month but am not sure if it gets me the 0.05c/minute rate that Int'l Long Distance Saver at $3 a month gets. What's the difference between the two add-ons?
Photo of Cameron Duder
Cameron Duder
  • 80 Points 75 badge 2x thumb
Photo of Daniel Kim
Daniel Kim, Mobile Master
I'm pretty sure they're both the same thing but the $2 one was before the add-on bumped up to $3. But just to make sure we should wait for a clarification :)
Photo of Chris Petersens
Chris Petersens
It's the same. What country are you calling? It's pretty easy to verify if you are getting the right rate. Just divide any of your calls to the country by the length of the call an you'll see what you are paying.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,496 Points 100k badge 2x thumb
The difference in name is mainly due to the fact that the ld saver plan is no longer required to dial international numbers, as international dialing has been enabled by default on all koodo accounts.
Cameron Duder
Thanks everyone. From what you've said it seems as if the old LD should get me the rate I'm wanting.
