  • Updated 4 months ago
Koodo has an iphone SE listed as "refreshed" available online - what does this mean? Same as refurbished/ certified pre-owned? Thanks
Photo of Thea Rae
Thea Rae
  • 82 Points 75 badge 2x thumb
Posted 4 months ago
Photo of Pedro Echeverri
Pedro Echeverri
  • 500 Points 500 badge 2x thumb
Previously owned or out of the box phone that gets new hardware parts put on the device then put back on the market at a better value.
Photo of Thea Rae
Thea Rae
Thanks. So "refreshed" is the same as refurbished/ certified pre-owned? Or is there a difference?
Photo of Allan
Allan, Mobile Master
  • 49,204 Points 20k badge 2x thumb
Yes, you'd be correct.
Photo of Brady
  • 160 Points 100 badge 2x thumb
I'm just trying to understand why Koodo would use 2 different descriptors to describe a "used" phone.  In both cases, would the phone only be used for a max 30 days?  Not sure why they have to make it so confusing -  the iPhones as "refreshed" and the Android phones "certified pre-owned".  Also, the certfied pre-owned iPhone only comes with a 6 month warrantty.
Photo of Dinh
Dinh, Mobile Master
  • 23,138 Points 20k badge 2x thumb
If you buy "refresh" iphone from Telus, and having one year warranty from Apple, then it will be as good as the new one.
