device protection plan if I bring my own device?
  • Updated 2 years ago
Hi Guys,
I'm currently with Telus with an older note 3. I've got the device protection plan on it, but was looking at a few different options with Koodo since my contract with Telus has been up for quite some time.
I know koodo has a similar extended warranty service, but is this available if I bring my own device over to koodo? Or does my phone have to be purchased new from Koodo directly?
Thanks!
Photo of Mark Warren
Mark Warren
Posted 2 years ago
Photo of Dennis
Dennis, Mobile Master
  • 196,772 Points 100k badge 2x thumb
Extended warranty is only availabe for new devices
https://www.esecuritel.com/koodomobile/Program_One
Mark Warren
Perfect, thanks for that info!
Does that mean I'm out of luck if I pre-ordered my Samsung note7 directly from Samsung Canada?
Photo of Jonathan I
Jonathan I, Mobile Master
Unfortunately yes, this won't apply. Does Samsung have their own protection.
Photo of Dennis
Correct.  You will have to get an extended warranty from samsung.
Personally, since you are buying the phone, outright, I recommend using a credit card with an extended warranty feature.  This will extend your manufacturer's warranty for 1 year against any manufacturer's defects (does not include any physical damage)
Mark Warren
Thanks guys for clarifying. It's the physical damage I like to protect myself against. I've seen good value in the Telus device protection plan over the years (even if it's just for peace of mind), so I will think it over a bit more and see what the best route to go is. Perhaps a tab plan will work out just as good for me if a protection plan can be added to that.
Mark Warren
Actually, that brings me to one other (although off-topic) tab related question...
I noticed tab large is only available on certain plans, where tab medium allows for a few more plans to select from.
Why is this the case? The price of the hardware doesn't change, so how come on a tab large the smallest "monthly plans" are more money than the tab medium ones.
Essentially, is this a form of "interest" on the tab large plans?
If you actually figure out all the math, the cost over a 24 month period is significantly higher on the cheapest tab large plan then the tab medium...(which shouldn't be the case if the hardware is the same right?)
Photo of Dennis
You got it right.
Since Koodo has to fork over a much larger subsidy, then they will need you to get a much larger plan in order to make up the cost of this "loan"
