default to home wifi
  • Updated 2 years ago
I have an iphone se.  I'd like the phone to default to my home isp whenever it is in range of the router. (or any other trusted data sites like work or school)  I'd also like to manually turn on the Koodo data when needed.
Is there like a priority or default setting  for iphone?
Photo of Ran Nauta
Ran Nauta
  • 74 Points
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 83,314 Points 50k badge 2x thumb
Pretty well any phone with wi-fi will connect to any saved networks if wi-fi setting is turned on in your phone, including your phone. Iphones also have a wi-fi assist feature to use device data if the signal is weak that you can turn on and off. You would hav to turn of wi-fi to switch to device data manually.
Photo of Dennis
Dennis, Mobile Master
  • 178,292 Points 100k badge 2x thumb
You can turn off data and manually turn it on when you need it
With Data turned off you will not be able to send picture messages (MMS) either.
If you want data off but still be able to send MMS, then you need to go to Settings>Cellular>Cellular Data and change the APN under cellular data (I personally just change the apn to sp.koodo.comZZZ).  Leave the the MMS APN unchanged.  Now MMS will work but data disabled (since the APN is incorrect).  To turn back on, just correct the APN by removing the "ZZZ"
