Data transfer between phones
  • Updated 2 years ago
Would I be able to take my old LG Optimus Black to a Koodo kiosk at a local mall and have them transfer all my data (contacts, photos, calendar, apps, etc.) to my new unlocked 32 GB LG Nexus 5 that i bought directly from Google.
*Note: my Google calendar won't sync over WiFi with the rest of my Google account (I cant access it on my computer or another device)
Photo of Braden Mamen
Braden Mamen
  • 112 Points 100 badge 2x thumb
Photo of HippieLongstocking
HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
Hey they Braden!
Yes a koodo kiosk will be able to do this for you. We have a special machine that allows us to move all pictures, sms, contacts to the new phone within in a couple of minutes :)
Braden Mamen
would you be able to sync my calendar too?
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
Since TeaBird hasn't gotten back to you I'll take my best stab at it (about 95% sure on this). No they won't be able to sync your calendar over.
HippieLongstocking
you are correct, we cant sync the calendar. if you have a gmail account it should automatically save that info in the backend and once you sign in on a new phone gives you the option to sync calendar. :)
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,376 Points 100k badge 2x thumb
That does assume, of course, that your phone is set to use google calendar instead of the phone calendar.
Photo of jackadision
jackadision
  • 60 Points
In order to copy old phone contacts and other data to new phone, you should use a professional Phone to Phone Transfer application. This app is one of the best way to transfer all typos of data from one phone to another with ease.
Photo of Sam Dmitruk
Sam Dmitruk
  • 384 Points 250 badge 2x thumb
I usually use Send Anywhere (download it on both phones and use WiFi to send files) or you could always use the traditional Bluetooth method of sending files.
Photo of Mayumi
Mayumi, Mobile Master
  • 115,056 Points 100k badge 2x thumb
I love Send Anywhere too :)
It's easy and works great.
