data problems with my cell phone
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
I Have gotten the 100Mb data boost plan on my cell phone Spet.17th and it is now October 14th and my cell phone will not let me use the data, keeps saying I dont have the data plan. can you please help me with this, either i want it fixed or the $ added back onto my cell cause i cant use it. :( would much rather the data though
Photo of Traci Travis W
Traci Travis W
Photo of Daniel Kim
Daniel Kim, Mobile Master
IT actually says on the phone that you can't use data because you dont have a data plan?
or if its just data thats not working, try a battery pull out or reboot then try resetting your network settings
Photo of quasarito
What is the model of you phone?
Photo of rikkster
rikkster, Mobile Master
  • 66,312 Points 50k badge 2x thumb
Hey Traci, we here in the community don't have access to your account details. If it's a limitation where the device is somehow preventing the add-on from being applied, or if you're seeking a credit for the amount of time the add-on has been inactive, a call to customer service is your best option at *611.
Photo of Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Traci, Booster Add-ons don't expire but base plans do! Did you renew your base plan (after 30 days)? That could explain why data doesn't work anymore! Thank you!
