data charging
Can you cancel charging on my data? It was mistake. I didn't want to use 3G with this phone, but my phone automatically catch 3G and koodo charge me $5. I asked it before and one of koodo person said it would be cancelled if I said. But It wasn't. Please give me feedback.
I am really satisfied with Koodo's service, so I want it last long.
Photo of Hyejin Chang
Hyejin Chang
  • 202 Points 100 badge 2x thumb
Photo of PD
PD
  • 6,798 Points 5k badge 2x thumb
If this is the new smart phone you activated, I would suggest you to disable data on your smart phone so it won't keep using the data silently. Call *611 and ask for the adjustment if this is genuine reason, koodo should definitely listen your voice.
Photo of Ahmad
Ahmad
Like PD said, your best option is to call Koodo at *611 from your Koodo phone. If you're on a plan with pay per use data which it looks like it, I'm not sure if you can actually remove it.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,538 Points 100k badge 2x thumb
You can call & have data blocked on your account but then you won't be able to send picture messages.
If you have an Android phone & you don't want to use data but still want to send/receive picture messages you can delete the Proxy & port from the APN settings for the Internet, which are the first Proxy & port in the APN settings. Don't delete the second set or that will eliminate the ability to send picture messages.
