Data booster add-ons with post paid plan.
Can I get a data booster add-on with a post paid plan or are they only for pre-paid plans?
Photo of Paul Goodfellow
Paul Goodfellow
  • 244 Points 100 badge 2x thumb
Photo of Ahmad
Ahmad
They are only for prepaid users. Sorry :(
Paul Goodfellow
Thanks. Yes I suspected that. I may just have to get a pre-paid SIM. It seems cheaper that paying for data on a plan.
Photo of Ahmad
Ahmad
Prepaid plans still require you to get a base plan and then you add the data booster. It should actually cost you more unless you are some ancient plan from 3 years back that has a horrible overage rate. Or you kept your non data plan throughout the years and just now realized you need data and switch to a plan with data now vs an old plan with no data is expensive. Just listing all the options why the scenario may be true, otherwise prepaid data is usually more expensive.
