Data and voicemail question
Hello. I just switched over to Koodo today from Bell and I have 2 questions. First, the data isn't working on my phone but I have a 1 GB data plan, Two, how do I set up my voice mail, my phone says voicemail isn't configured. I don't have a voicemail number. Please help!
Photo of Debbie Sinasac
Debbie Sinasac
Photo of Camilo_A
Camilo_A
  • 31,072 Points 20k badge 2x thumb
Hi there... Press on number 1 for a couple of seconds and this will connect you with the VM, then you can set it up...
Then for data, you may power cycle your phone to see if it works, and also you may check the following link to see if the data settings are ok...
http://koodomobile.com/en/ab/non-kood...
Photo of Reena
Reena
  • 4,244 Points 4k badge 2x thumb
Hi Debbie
First, Congrats for moving to Koodo. To set up the voicemail hold down the number one key on the keypad and it'll dial you right into the voicemail to set it up. The data can be configured by making sure the apn is set to koodo. Make sure the wifi is off and data turned on and make sure the apn is as follows:
Tap New APN on the bottom of the screen and enter the following information:
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http://aliasredirect.net/proxy/koodo/...
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: None
APN type: leave blank
Tap menu
Tap Save
make sure the /mmsc is after the koodo for the "mmsc"
