Data won't work
  • Updated 2 years ago
I bought a Samsung Galaxy S6 a month ago and have a plan that includes data. Mobile data setting is enabled on the phone and I have the APN set how the koodo website instructs but the data has never worked. When I try the built-in internet app I get the message, "Wifi and mobile data are turned off." But both are on and I only get internet access with wifi. Any help would be appreciated.
Photo of DarkTwinDX .
DarkTwinDX .
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 103,784 Points 100k badge 2x thumb
Hello Dark.
Do.you have a data block on your account?
DarkTwinDX .
Never used any data at all, so I don't see how. And I never received a text telling me so.
DarkTwinDX .
I did indeed have a data block on by default and could not remove it from self serve, I'm not sure why this would be but it is now removed. Thanks so much.
Photo of Daniel
Daniel, Employee
  • 5,712 Points 5k badge 2x thumb
Hey Dark! You can check in your Self Serve (http://koo.do/1TjB0RW) if you do have a data block. You can remove it yourself if it is there.
Let us know :)
Photo of Robert
We can remove ourselves?
Photo of Melissa
Melissa, Employee
  • 11,748 Points 10k badge 2x thumb
Hey Robert, you're right, the data block can only be removed by calling us in.  Thanks for pointing that out!
