data won't work
  • 2
  • Updated 1 year ago
I usually keep my data turned off and just use WiFi, and now when I try to switch on my data it doesn't work. Does anyone know how to fix this? Thanks
Photo of chista
chista
Posted 3 years ago
  • 2
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,270 Points 100k badge 2x thumb
Make sure your APN settings are set to those of Koodo's settings below.
Name KOODO
APN sp.koodo.com
Proxy leave blank
Port leave blank
Username leave blank
Password leave blank
Server leave blank
MMSC http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy 74.49.0.18
MMS Port 80
MCC 302
MNC 220
Authentication type None
APN type leave blank
APN Protocol IPv4
APN roaming protocol IPv4
Enable/Disable APN APN enabled
Bearer Unspecified
Photo of st Clifford
st Clifford
  • 172 Points 100 badge 2x thumb
I have a nexus 4, i checked all these settings and my data is still workin, any more suggestions?
st Clifford
I just switched to a plan that includes 100mb data for the first time, i have set the warning and limits on my phone.
Photo of Mayumi
Mayumi, Mobile Master
  • 115,056 Points 100k badge 2x thumb
So, your data doesn't work?
You should check your add on. You might have Data block on your account.
Photo of chista
chista
Thanks! I also tried powering off with the WiFi off and data on, and it worked.
Photo of Angela Spires
Angela Spires
  • 60 Points
Worked! Thanks so much!
Photo of Allan
Allan, Mobile Master
  • 61,136 Points 50k badge 2x thumb
Glad to hear this worked for you! Next time though, we suggest you make a "Praise" thread instead of reviving old ones that have already been answered.
https://community.koodomobile.com/koodo/topics/new
