data won't turn on
  • Updated 2 years ago
I have a 50mb data plan and I haven't used any of the data this billing period, but the data won't connect. I've tried EVERYTHING except talk to koodo and nothing seems to be working.
Photo of Trista Belanger
Trista Belanger
Posted 2 years ago
Photo of Ivan
Ivan, Mobile Master
What is everything?
Have you ever had a data block on your account? This old add-on requires a call to customer service to remove. Otherwise:
1. Make sure data is on in your phone's settings.
2. Make sure your APN settings are correct (guide says for Android, but the values are the same for any phone): http://aide.koodomobile.com/plans-add-ons-data-and-other-services/data-on-android/How-do-I-setup-dat...
3. If using an iPhone make sure the app you're using is permitted to use cellular data: http://www.imore.com/how-turn-cellular-data-specific-apps-iphone
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,938 Points 100k badge 2x thumb
Did you log into your self serve to make sure you haven't accidently used your data allotment, I mean 50mb can be gone in the blink of an eye.
Photo of Tayeb A
Tayeb A, Employee
  • 18,208 Points 10k badge 2x thumb
Hey Trista,
Feel free to send us a private message on Facebook or a Direct Message via Twitter so we can look into this.
We look forward to assisting you!
