Data usage summary does not match the detailed usage
  • Updated 9 months ago
I recently added an iphone to my account and the data usage summary says 650MB, however when I look at the detailed usage it says 2GB (which matches what the phone's tracker says). When I look at my other two lines the summary and detailed info is accurate (both android). Why is this?
Photo of Erin Meston
Erin Meston
  • 102 Points 100 badge 2x thumb
Posted 9 months ago
Photo of David
David, Mobile Master
  • 88,942 Points 50k badge 2x thumb
Have you reset the iPhone at the beginning of each billing period? It does not do so itself.
Photo of Robert
Robert, Mobile Master
  • 103,372 Points 100k badge 2x thumb
Because iPhone's data calculation system is stupid and you can't set it to restart every month. On the other hand, Android does it by itself, that's why the difference
Photo of David
Alternately, the iPhone reset works better with prepaid options such as Public Mobiles 120 day plan.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
Is it a new line, or just a new phone? For new activations the first ten days of data are usually zero rated, which means that the first ten days of usage wouldn't have counted toward your monthly limit.
Erin Meston
Yes! It is a new activation, so that makes sense!
