Data Showing For Same Day on Regular Data Plan and Bonus Data Plan
  • Updated 6 months ago
Recently added the 2GB bonus onto the regular shock free data plan. Appears the same amounts of data for the same days is being assigned to each of the two plans. That doesn't appear to be a 2GB bonus. Someone able to clarify?
Photo of Dave Buxton
Dave Buxton
Posted 6 months ago
Photo of Allan
Allan, Mobile Master
  • 56,776 Points 50k badge 2x thumb
Could you take a screenshot of what you're seeing and post it here for us to see as well?
Dave Buxton
Photo of Allan
  • 56,056 Points 50k badge 2x thumb
When you click view details on the 2GB does the data usage times match up with those of the 6GB?
I'm thinking it was just a sort of glitch that decided to show usage on the 2GB side one day and then it switched back.
Dave Buxton
Exact dates and times for both for more than one day
Photo of Dinh
Dinh, Mobile Master
  • 31,322 Points 20k badge 2x thumb
If 2 data buckets were taken out at the same time, you would have to contact Koodo (calling or messages through their facebook) to get it fixed.
Photo of Robert
Robert, Mobile Master
  • 102,958 Points 100k badge 2x thumb
Here's the link for FB contact : www.m.me/Koodo
Dave Buxton
Thanks, will give it a try
Photo of Camilo_A
Camilo_A
  • 31,052 Points 20k badge 2x thumb
Hi there!
I would say, no need to call Koodo for this one... Since you recently added the 2GB, it will show in your Self Serve exactly as your screenshot... in 2 separate circles!... When cycle ends, you should see a consolidated usage... Buttom line, you have 8 GB from what I see.
Enjoy!
