data & service problem
  • Updated 2 years ago
my internet is not working at all . i have almost a gig of data but it will not work i tried turning flight mode on & off but it is still not doing anything ... also my picture txt hasnt worked in a while any suggestions ((koodo fix my service  please ))  i shouldnt have to pay to fix these problems  im paying for stuff i cant use !! i have a samsung ace 2 ,$35 pre-paid plan London.ON Canada
Photo of R.J. De Groat
R.J. De Groat
  • 190 Points 100 badge 2x thumb
  • not pleased
Posted 2 years ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
Open the settings menu.
Tap More...
Tap Mobile network.
Tap Access Point Names.
Press the Menu button
Tap New APN:
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Tap menu key, then tap Save.
Tap the radio button at the right of the Koodo APN to activate data services.
Photo of BobTheElectrician
BobTheElectrician
  • 61,736 Points 50k badge 2x thumb
And when you get back to a more main menu, make sure that mobile data is ON in that setting. And then reboot.
Photo of Tiz
Tiz
  • 4,604 Points 4k badge 2x thumb
It is funny, I checked my phone and it only say sp.koodo.com all the rest is blank. The phone is working like a breeze.
Photo of rikkster
rikkster, Mobile Master
  • 67,080 Points 50k badge 2x thumb
On my Galaxy Ace 2x, the APN type is set to: default, mms (exactly as shown). Default indicates the default mobile data connection, mms indicates an MMS-specific mobile data connection. MMS is an abbreviation for Multimedia Messaging Service. Picture messages are sent/received using this service.
Photo of Melissa
Melissa, Employee
  • 11,748 Points 10k badge 2x thumb
Hey R.J! Did the above suggestions help? Is your data working now? Let us know!
R.J. De Groat
Sry. Yea it worked for data . But picture txt is still not .
Any suggestions to fix it .
Photo of rikkster
If picture messaging is still not working, set the APN type to default. You can also try an asterisk, without the brackets (*) if default doesn't work. Remember to save the modification before exiting. If you have more than one APN set up, delete/discard the one you're not using. A reboot of the phone normally isn't necessary after modifying the APN, but it doesn't hurt. Make sure to save any modifications to the APN before rebooting.
R.J. De Groat
Thank you for the help with that :)
