Data Roaming in home country
  • Updated 2 years ago
I accidentally turned on data roaming while in my home country. Will I get charged for this? I attempted to send a picture through WhatsApp but it did not send. I have a Samsung Galaxy with 300 MB
Photo of Angel
Angel
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Sophia
Sophia, Mobile Master
Well, if it connected to the cell tower and used data, then yes, you will be charged $5 per MB (depending on the country you're in). Let's hope it didn't work :)
Edit: here is where you can calculate your cost: http://help.koodomobile.com/coverage-long-distance-and-travelling/travelling
Photo of Goran
Goran, Mobile Master
  • 90,950 Points 50k badge 2x thumb
You need the international roaming add-ons that enable roaming first actually.
If it didn't send then you likely didn't have the add-ons enabled for roaming.
