Data Roaming Disabled
  • Updated 4 months ago
Hi! I got a plan with Koodo and it originally didn't have data on it, so I asked the guys to help me disable data roaming so I could never accidentally use it or get charged for it. But now I switched to a plan with data and I have no idea how to turn data roaming back on. It's somewhere on the website because I went into a Koodo store today to ask and a lady said to just change it on the website. Could anyone tell me how to do it?
Photo of Sisi Zheng
Sisi Zheng
  • 142 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Dennis
Dennis, Mobile Master
  • 187,452 Points 100k badge 2x thumb
Data roaming would be using data while in a foreign country.  I think you want to remove data block.
You need to go to self serve and you should be able to see it in your add-ons.  You just need to remove it from your add-ons
Photo of Bernard
Bernard, Official Rep
  • 75,560 Points 50k badge 2x thumb
@ Sisi, what name is your account under?
Photo of Sisi Zheng
Sisi Zheng
Peimei Xie
Photo of Bernard
Ok, try it now. First turn phone on and off.
Photo of Sisi Zheng
Sisi Zheng
thank you so much!! it is working now:)
Photo of Cedrick Ward
Cedrick Ward
  • 80 Points 75 badge 2x thumb
I had the same problem. I realized this was solved internally, but for the sake of clarity, I had to go to Self-Serve > Mobile Services > Manage add-ons.
I then removed it from there.
Photo of Sisi Zheng
Sisi Zheng
This reply was created from a merged topic originally titled Data Roaming Disabled.
