Data problem - iphone 6
  • Updated 11 months ago
Hi, I switched yesterday from iphone 5 to 6. I never had any problem with my data but now it doesn't work. Only wifi does. I tried to restore to factory setting and it still doesn't work. Any help would be appreciated because the situation is frustrating.
Photo of Melissa
Melissa
  • 150 Points 100 badge 2x thumb
Posted 11 months ago
Photo of Goran
Goran, Mobile Master
  • 91,244 Points 50k badge 2x thumb
Check your APN settings to see that they match. Is data turned on? You said youre prepaid so do you have an active data booster atm?
Photo of Melissa
Melissa
Hi, I don't have one sadly. All I know is that it was working on my former phone (iphone 5) that I was still using the day before I changed it (been sold since so I can't test).
Photo of Robert
Robert, Mobile Master
  • 103,888 Points 100k badge 2x thumb
Are the settings on the new iPhone ok? What I mean by that is do you have data turned on? Is safari enabled to use cellular data?
I know it's stupid but looks like you tried everything
Photo of Melissa
Melissa
I checked the APN like suggested. It was fine. Everything on my new phone is ok. I recharged my data the day after I got my phone and none had been used ever since. Even though I open it and tried many times. When I open my data to try on Safari, it shows up as picture below. I do have data so I don't why this is happening.
Photo of David
David, Mobile Master
  • 89,450 Points 50k badge 2x thumb
I take it you also can't access mapsWeather or stocks either?
May be time to contact Koodo to see if they can reset your account.
Photo of Melissa
Melissa
I can access both on wifi. I went to Koodo store and the man told nothing is wrong with my phone about the data, or the access. and that I need to contact Apple directly, that they will be able to help me.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Reset the Device Network Settings & Reboot the Device. The next troubleshooting step is to reset iOS network settings, and then turn the iPhone off and back on again. This can often resolve cellular data failures and it's pretty simple: ... Now hold down the Power button and turn the iPhone off.
Or
Turn off SIM PIN, if you have accidentally enabled it. SIM PIN is used to prevent access to cellular data network. If you want to use cellular data, you need to enter the PIN when you swap SIM cards or happen to restart your iPhone . One thing is to be remembered, it applies to devices that works with SIM card.
Step #1. Launch Settings app.
Step #2. Scroll down and tap on Phone.
Phone App Settings in iPhoneStep #3. Tap on SIM PIN.
iPhone SIM Pin SettingsStep #4. Switch off SIM PIN
Photo of Melissa
Melissa
1. I had done that unsuccessfully.
2. No SIM pin on
Have you tried a factory reset as the last resort and see if that does it? You are completely up to date with software updates and running the most recent version of IOS on the phone as well correct?
Edit: sorry noticed just now that you said you did a factory reset my bad. You are running the most recent version of IOS though correct?
Photo of Melissa
Melissa
It was updated when I unlock the phone. So yes.
Photo of Cory
Cory
  • 10,482 Points 10k badge 2x thumb
I could be wrong, but don't you have to plug it into iTunes and do a restore after unlocking/changing carriers with iPhone to activate it?
I forget, it's been a while since I had an iPhone.
Photo of David
  • 88,446 Points 50k badge 2x thumb
According to Apple, no, but sometimes it is easier to do so.  That calling & text works indicates the unlock has been processed, but the data network is not connecting to the phone.
