data plan issues
  • Updated 10 months ago
I bought 55$ plan including 2GB for my phone, but somehow its not working since I reactivated my phone. How can I fix this problem? Thanks for you kind service.
Photo of Phillip Kim
Phillip Kim
  • 90 Points 75 badge 2x thumb
Posted 10 months ago
Photo of Robert
Robert, Mobile Master
  • 107,614 Points 100k badge 2x thumb
Hello Phillip Kim,
Did you already have data before that on your plan?
Phillip Kim
I did not have data before I got the plan thanks.
Photo of David
David, Mobile Master
  • 93,800 Points 50k badge 2x thumb
And has the phone been used on a different carrier before you reactivated it on Koodo?
Phillip Kim
I have changed my phone from LG G5 > LG V20
Photo of David
Make sure your APN settings are correct. Here is one link, but there are other descriptions to be found by searching 'APN' in the search bar.
