Data plan is not working? It says I have it but I cannot connect to Internet using data.
  • Updated 11 months ago
Have the 30 plan for the US but the data won't
Work. I have data enabled in my settings but I cannot connect to the Internet without wifi.
Photo of Natalie A Schaff
Natalie A Schaff
  • 182 Points 100 badge 2x thumb
  • frustrated
Posted 11 months ago
Photo of Robert
Robert, Mobile Master
  • 106,704 Points 100k badge 2x thumb
Hello Natalie,
Did you activate data roaming on your phone?
Photo of Goran
Goran, Mobile Master
  • 96,868 Points 50k badge 2x thumb
Did you also enable data roaming? Try restartinyour phone after you check
Natalie A Schaff
Yes roaming is activated.
Natalie A Schaff
Restarting did not help.
Natalie A Schaff
I don't usually carry a plan in Canada but got the plan for while I am in the states. Could this be an issue? For $75 I better get this to work.
Natalie A Schaff
My wifi is spotty. Still hoping for a response
Photo of David
David, Mobile Master
  • 93,338 Points 50k badge 2x thumb
Your phone should work for pay-per-use data even without a plan. Do you have a data block on your phone, to,prevent overages in Canada? If so that may be the root of your problem.
Natalie A Schaff
Yes that could be. How do I fix it?
Photo of Mayumi
Mayumi, Mobile Master
  • 114,740 Points 100k badge 2x thumb
If you have a data block, then you have to contact Koodo to remove it.
Send them a PM through FB and request it.
https://www.facebook.com/Koodo
Photo of Kim Dillon
Kim Dillon
Hey! I am having the same problem as Natalie. I also enabled roaming. How does one stop the data blocking? What is the procedure?
Photo of Mayumi
  • 114,738 Points 100k badge 2x thumb
Did you restart your phone?  Did you get a Roaming add-on?
Make sure you have a $0 International Data Roaming add-on activated.
Login to self serve and check it. Also if you have a data block ion your account.
If you have an add-on : Data block w pics, then you might be able to removed it through self serve. But if you get an error message, you need to contact them.
Photo of BobTheElectrician
BobTheElectrician
  • 67,038 Points 50k badge 2x thumb
On an Android phone, there are a few additional things you can try if US roaming is not working:
In your mobile network settings, change network type to EXCLUDE LTE. Some locations may only be working on the older 3G standard.
In network providers, deselect automatic and let the phone populate with the eligible local networks (may take a few minutes). Then select either AT&T or T-Mobile manually.
Don't forget to revert the setting when you get back to Canada.
