Data on roaming pkg.
For U. S. roaming pkg. is the long distance charge extra and what is the cost, I was thinking of the $75.mth cost. Now, my data is turned off at present would I turn this on myslf before leaving if I chose to go this route ? Thankyou Moira
Photo of Walter DesRosier
Walter DesRosier
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Curtis
Curtis
  • 1,330 Points 1k badge 2x thumb
Hi Walter,
Don't worry, long distance in the U.S. is covered with the roaming add-on. So you can call from the U.S. to anywhere in the U.S. or Canada with no additional fees.
If you do decide to go with roaming data, don't forget to turn data roaming on in your phone. It's usually off by default.
________________________
