Data not working
  • Updated 2 years ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: archiving 611
I got a Samsung s5 neo recently and changed to a new plan including 100MB of data, but I can't seem to get it to work. I don't have a data block on my account. Any help would be appreciated!
Photo of ellen
ellen
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,558 Points 100k badge 2x thumb
Are your APN settings set to Koodo under mobile networks in your phones settings?
Make sure data is enabled in settings under data usage.
Did you check self serve to see if you have a data block on the account since you've made the change to the new plan?
Photo of ellen
ellen
I checked all of that, APN is set to koodo, mobile data is enabled and just don't seem to have a data block when I checked self serve
Photo of BobTheElectrician
BobTheElectrician
  • 61,920 Points 50k badge 2x thumb
Simple step easily forgotten: re-start the phone to refresh the connections. If the problem persists, send Koodo a private message on their Facebook page, since it seems *611 has a big backlog.
Photo of Nabil
Nabil, Employee
  • 6,640 Points 5k badge 2x thumb
Hi Ellen,
Still experiencing issue? Still not able to access data? If the APN is correct, you probable have a data block on your account. In this case you need to contact us since it is no longer possible to remove it from the Self-Serve.
Thanks
