Data not working showing lte but not working
  • Updated 4 weeks ago
I have a iPhone x on 11.3.1 and date was working till yesterday I don’t know what happened now data doesn’t work it shows I have full range and shows lte on the top but it doesn’t work
Photo of gurkirat dhot
gurkirat dhot
Posted 4 weeks ago
Photo of Dennis
Dennis, Mobile Master
  • 201,104 Points 100k badge 2x thumb
Restart your phone.
If that doesn't work go Settings > Reset > Reset Network Settings. Note that wifi passwords and Bluetooth pairings will be lost
Photo of Dinh
Dinh, Mobile Master
  • 45,986 Points 20k badge 2x thumb
Also, I would suggest you check your selfserve to check if your data bucket for the month has been used.
Photo of Mats
Mats
  • 24,654 Points 20k badge 2x thumb
Another thing to check if Dennis suggestion doesnt work. If you're on prepaid do you have any data left on your data booster?
If you're on postpaid was your data used up and paused? Link to unpause and buy more.
https://www.koodomobile.com/help/pausing-and-resuming-data
