Data not working how fix
  • Updated 9 months ago
Kodoo prepaid got data but not working how to fix? Lg k4. Was with telus switched to kodoo. I set the apn removed sim card and battery and did a factory reset. Mobile network status is discounted but can use voice and text.
Photo of Joanne Macneil
Joanne Macneil
  • 160 Points 100 badge 2x thumb
Posted 9 months ago
Photo of Sophia
Sophia, Mobile Master
What did you set the APN to?
Joanne Macneil
The koodo apn that I found on the forms
Photo of Sophia
  • 142,824 Points 100k badge 2x thumb
Can you post a screenshot of your settings?
Joanne Macneil
Got it working it put spaces in it.
