Data not working after changing plans with data?
  • 2
  • Updated 2 years ago
  • (Edited)
I have a Samsung Galaxy S4, bought from Koodo. I've been on a $30 plan with no data for almost a year.
Last night, I checked the plans available and realized that I could change my plan to one with 100MB of data for the same price, and so I did.
Unfortunately, even now, using the default APN provided after a factory reset ("Koodo SP"), I cannot connect to use data.
APN: sp.koodo.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: http://aliasredirect.net/proxy/koodo/mmsc
MMS proxy: 74.49.0.18
MMS port: 80
MMC: 302
MNC: 220
Authentication type: None
APN type: default,mms,supl,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
Enable/disable APN: APN Enabled
Bearer: Unspecified
Mobile virtual network operator type: GID
Mobile virtual network operator value: 4B
Phone/Text works, MMS doesn't.
Mobile Data is toggled on, tried roaming on and off.
WiFi is off.
No VPN is set up.
Although my previous plan did not have data, I did not have the $2 Data Block w/ Pic Msg as a monthly addon.
I've tried various other APNs available, but the phone deletes anything that isn't set a MVNO of "4B". For example, entering "4D4F" as a MNVO and attempting to save it will automatically delete the APN.
Tried adding a proxy of 74.49.0.18:80, didn't work.
Restarted device multiple times.
Toggled airplane mode multiple times.
Tried a factory reset, didn't work.
Is it possible that my data was automatically blocked somehow because I had no data in my previous plan?
Photo of Dan Ho
Dan Ho
  • 152 Points 100 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Did you have a Data Block add-on?
Photo of Dan Ho
Dan Ho
Did picture messages ever work for you? That data block is new and may be called something else in your add ons.
Photo of Dan Ho
Dan Ho
Picture messages never worked, I didn't have data for them in my previous plan either. They still don't work now that I supposedly have 100MB of data.
I don't have any addons.
You need to contact koodo and see if a block was added to your account. Picture messages, while requiring data to be on, do not count against data use. So if picture Messaging never worked to begin with then I see a possibility of a data block on Koodos end. Give Tech support a call in the morning, tell them what you've already tried.
Photo of Dan Ho
Dan Ho
I don't think I've ever had mobile data on until now because I didn't want to incur any fees, but I'll definitely call Tech support tomorrow.
Photo of Goran
Goran, Mobile Master
  • 91,316 Points 50k badge 2x thumb
Try pulling the Sim card in and out. Give it a minute.
Photo of Dan Ho
Dan Ho
Didn't work.
Photo of Christopher Sarao
Christopher Sarao
  • 80 Points 75 badge 2x thumb
Please keep us informed if you find your problem, I'm in the same boat as you.
Photo of Dan Ho
Dan Ho
PROBLEM SOLVED:
It seems that Koodo has a data block implemented on their side (probably to prevent people from incurring extra charges when they had no data), regardless if you have opted for a Data Block in your monthly add-ons.
Just called to have tech support check up on my account, and had it removed.
After following the instruction of removing my battery, 4G is now working.
Glad you got it working
