Data I have versus what self help says
  • Updated 2 years ago
  • (Edited)
My plan shows that I am able to use 250 mb of data but when I look at the self serve it shows I have used 51 and I'm in the red. I don't understand. It doesn't show any other usage but I have additional data charges of $10
Photo of Barb Westcott Fontaine
  • extremely frustrated
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 96,970 Points 50k badge 2x thumb
Did you recently change your plan? If so, then the data amount is prorated. So if say you changed it 6 days before the end of the billing cycle x you'd get around 50MB of data to use until then.
No I haven't.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,496 Points 100k badge 2x thumb
Are you certain it says MB and not kB?
Yes it's mb
Yes it's mb
Photo of Bernard
Bernard, Official Rep
  • 80,726 Points 50k badge 2x thumb
@ Barb you have 3 lines on the account. The one ending with phone # 47 did indeed have a plan change very recently. Is that the one you are inquiring about? If not, can you pls tell me which? Last two digits are enough for me to see. Of the 3 lines only 2 have plans with data included, albeit neither one is with 250MB.
Photo of Bernard
Ok, that line has a talk & text plan on it. Meaning you don't have any data included in the plan. You can use data, but it will be on a pay-per-use basis with our data saver. The reason it's red to show that you will have incurred extra charges over an above the monthly price of your plan.
