Data connection not possible on LG
  • 2
  • Updated 1 year ago
  • (Edited)
Hello, I am not able to access the data network on my LG phone, I've tried restarting, I've re-entered all the apn information, I have even done a factory reset and despite backing up my phone, lost all my contacts....needless to say I'm stumped. I have a prepaid account with plenty of data remaining. How do I fix this??
Photo of Lisa G
Lisa G
Posted 1 year ago
  • 2
Photo of Mathieu
Mathieu, Mobile Master
Hi Lisa,
Are you sure your baseplan is active?
Photo of Lisa G
Lisa G
Yes, it is active until June 3
Photo of Nilesh Patel
Nilesh Patel
  • 72 Points
I have same problem too.
Which LG phone do you have?
Can you post screenshots of your APN settings?
Photo of Lisa G
Lisa G
I have an LG K7 , here are my apn settings
Photo of Lisa G
Lisa G
Mobile data is on, no limit set, there is only one APN and it is koodo.sp and it is selected. I took my phone into koodo this morning and they verified all my settings.
Are you able to text and make phone calls?
Where did you buy your phone?
Photo of Lisa G
Lisa G
I am able to make phone calls, and standard texts. It is from Best Buy, I've had it for 6 months and it previously worked fine.
Nilesh Patel
  • 72 Points
Try this, insert other friend sim card and should be your carrier send you a apn setting by text accept all and should you able to get i ternet. Then insert your sim. I did same and its work now.
