Data connection issue
  • 3
I'm having data connection issues. I normally don't have my phone data enable on and I'm not able to get a connection this week. It was working last week so my APN setting is correct. My daughter is having the same issue. We're in Calgary
Photo of L Wong
L Wong
  • 40 Points
  • confused
Posted 3 years ago
  • 3
Photo of L Wong
L Wong
  • 40 Points
Problem solved. I cycled my phone (turned off/on) and did the job. I guess Telus/Koodo system had a hiccup.
Photo of Dennis
Dennis, Mobile Master
  • 184,940 Points 100k badge 2x thumb
Glad it worked out
Photo of MD
MD
  • 1,280 Points 1k badge 2x thumb
I'm in the same boat: I use Power Toggles to flip between wifi and mobile data (AutomateIt didn't work well for me) and I found that after a while (a week maybe?) mobile data stops working. I don't even get the icon in the upper bar.
Only solution (as you discovered) is to reset the phone (power-cycle).
Note3 on KK 4.4.2 here.
