Data Charge Question
  • Updated 2 years ago
Hi I'm new with this whole Data thing. I took a look at my bill and I was charged $10.67 for data usage on my 2GB plan. Was I charged for going over or do I get charged just for using the data?
Photo of Trevor Patrick
Trevor Patrick
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 106,784 Points 100k badge 2x thumb
Hello Trevor.
Take a look at page 3 of your bill. You'll see everything explained there. I believe it's because you went over your data limit. But I can not be 100% sure because I have no access you your account!
Trevor Patrick
I monitored my data via my phone
Photo of Goran
Goran, Mobile Master
  • 96,970 Points 50k badge 2x thumb
Ah ok. So you did not get overcharged. It was pro-rated a sit's your first bill. Here watch this:
http://help.koodomobile.com/my-bill/charges-explained/charges-on-your-first-bill
Trevor Patrick
Oh ok thanks! Much appreciated! So next month I'll only get charged if I go over?
Photo of Robert
Yes. And you can set up notification via self serve so you don't go over!
Trevor Patrick
oh ok thanks! Much appreciated, thanks for the quick response, I thought something looked weird at first but now it's all cleared up! :D
