Data block clarification
  • Updated 2 months ago
So, my daughter had a samsung and now has an iphone which uses data up like crazy (apparently this is an iphone thing). She has her data (1GB with our plan) off most of the time but cannot receive pictures via text unless she turns it back on - which is a pain turning off and on to control her data usage. If i add the Data Block to her plan, will she still be able to access apps and internet as long as she is connected to wifi? Just trying to figure out if this add on is a benefit or not to help her control her data usage. Thanks!
Photo of Heather Bonney Relva
Posted 2 months ago
Photo of Mayumi
Mayumi, Mobile Master
  • 111,386 Points 100k badge 2x thumb
If you added this add-on, then she can't access her 1 GB tho.
Check her phone setting if there is WIFI assist on or update background app through wifi only...etc
So, they can block her 1GB data, but they can't stop her from going over her 1GB? Sounds fishy.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 193,200 Points 100k badge 2x thumb
If she has a shock free plan then it will stop when she reaches her limit and she will have to text a response to Koodo to keep using more data above her allotment of 1gb. If she doesn't have a shock free plan then not it will not stop when reached
Photo of Dinh
Dinh, Mobile Master
  • 24,156 Points 20k badge 2x thumb
Her data would be stopped at 1GB.
Koodo data automatically stops when users reach 100% (if you set up in your selfserve). UsersĀ  have to agree for overage before using more data.
Photo of Dennis
Dennis, Mobile Master
  • 178,334 Points 100k badge 2x thumb
All plans are shock free plans now
Photo of BobTheElectrician
  • 57,498 Points 50k badge 2x thumb
Yes. The $2 a month data block shuts everything down except for multimedia texts. Her wifi will continue to work as usual. That's completely independent of mobile data.
Photo of Robert
Robert, Mobile Master
  • 101,484 Points 100k badge 2x thumb
Hello Heather,
Adding the add-on is not the right option in order to control the data on your daughter's phone. The best option is SFD which is available on all plans.
Photo of Allan
Allan, Mobile Master
  • 50,828 Points 50k badge 2x thumb
All plans with Koodo have shock free data now as well so there shouldnt be a problem here...
Photo of Frank Piccolo
Frank Piccolo
  • 396 Points 250 badge 2x thumb
In Settings, goto Cellular, scroll down and toggle off apps which you do not use. Apps such as Facebook can eat up data ike crazy. Then toggle off iCloud Drive and Wifi Assist if your wifi network is solid.
