Cross-border roaming
  • 2
  • Updated 4 days ago
Just got a msg that my son's phone is roaming on a US network. (He's on the QC side of the Can/US border.) The msg tells me (the authorised account holder) that I can manage his settings and set permissions on the self-serve page. I can't see this option, though. Could anyone help me, please. (He has an iphone 6S.)
Photo of Jeanine Floyd
Jeanine Floyd
  • 196 Points 100 badge 2x thumb
  • frustrated
Posted 5 days ago
  • 2
Photo of David
David, Mobile Master
  • 88,974 Points 50k badge 2x thumb
You can choose roaming options such as EasyRoam, etc from self-serve. You can’t control his phone. If your son is not entering the USA, advise him to enter his settings, go to Carrier, turn off Automatic selection of carrier, then select Koodo from the list which populates. This will keep his phone connected to Koodo, rather than connecting to a US carrier when near the border.
Photo of Camilo_A
Camilo_A
  • 31,012 Points 20k badge 2x thumb
Hi there!
As far as I know, you will be able to set limits when it comes about Data... If you log into you Self Serve account, then go to usage (for the number you want to set parameters) then click on change data settings, then in this section you will be able to make changes when it comes about accepting extra charges...
If you dont want the phone to connect to a USA tower, you can also modify the phone settings to pick only Koodo's network... This will be under mobile network menu on your phone depending on the model...
Let us know.
Photo of DavidRezaei
DavidRezaei
  • 62 Points
It happens to me too I was in Niagra falls in Canada and I received message says roaming
Photo of Mats
Mats
  • 10,994 Points 10k badge 2x thumb
This happens to everyone that is close to the border and "automatic" is set for mobile networks. This allows your phone to roam and connect to a US network. As David and Camilo said, set mobile networks to "manual" and then select Koodo. You will not receive roaming warnings anymore. If you ever do want to roam then set it back to automatic.
Jeanine Floyd
Thanks, everyone. I've passed on the info to my son, and will check my own phone, too.
